state police/highway patrol
mlevin
Baltimore, MD
will be traveling through the state in july.anybody know the freqs for the state police / highway patrol?are they trunked or conventional?any info is helpful.
Truckiee23
Woodbridge,Va
158.985, 159.000, 159.1350, and 159.1650
You will have to scan these frequencies depending on where you will be. VSP uses these all through out the state.
Samuel
Prince William, Virginia
VSP uses those 4 frequencies to get 14 channels by using PL tones... if you have a scanner that has that feature you might want to program the frequencies in that way for less interference. There are 7 divisions. Each division has 2 channels each.
garys
Central Texas
What type of scanner are you using? I have an Excel program for use with Andy's 780XLT programmer that has most of the VSP info on it.
Gary
mlevin
Baltimore, MD
whoa! wait a second whats a pl tone,i'm going to be using a 250d and/or pro94.do you know what divisions use which freqs.thanks for the fast response.
InTheShire
Arlington, VA
Input Frequencies
Hello all. With regard to the VA State Police info page in the database section, what are the "Input" frequencies for?
paul34
Texas
Virginia SP operate on a conventional repeater-based system. A repeater is a receiver/transmitter that operates at fairly high power, and is usually situated on a tall tower or hill (or a tall tower on a hill) so that it has a large coverage area.
Individual user radios transmit on the repeater input frequency and receive on the repeater output frequency. The repeater receives on the input frequency, then rebroadcasts on the output frequency.
Why? Well, VHF pretty much travels line-of-sight (you can get some reflected signal over the horizon, but don't count on it). From one car to another, without using a repeater you could only get reliable communications over a 4-7 mile radius (distance to the horizon). Since the repeater antenna is much higher than the antenna on top of the vehicle, it can receive over typically a 20-30 mile radius. Plus, the repeaters can be linked through land-line connections or microwave links to give effective coverage over a much wider area.
Some of the implications for scannists:
  • * If you want to conserve memory, only program the output frequencies.
    * If you want to take special notice of nearby units, also program the input frequencies (if you hear something on one of these, the source is typically only a couple of miles away).
    * When listening on the input, if you do hear a transmission, it is typical that you will only hear 1/2 of the conversation (the half coming from the source near you).
ScanManQSL
QTH: Montgomery County, MD / Washington, DC
What is the input frequency for the repeaters?
I think i have found the question to my answer: :lol: . . .
154.905 - State police, input to 158.985
154.935 - State police, input to 159.000
155.46 - State police, input to 159.135
155.445 - State police, input to 159.165
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
ScanManQSL said:
What are the input frequency for the repeaters?
paul34 explaned their use and my link above and RR Datbase list the input freqs for each output. But also stated previously, if you scan the output, you'll hear both sides of conversation, while input may only give you one side.
Example, the Wytheville repeater is on a very high knob on Clinch Mountion in the SW part of the state. Talk about range...
input 154.935 match with 159.000
input 155.445 match with 159.165
I believe Appomattox, Salem and Culpeper also use a mountain tops.
MOTORHEAD3902
outskirts of tar bay
For better coverage, the VSP uses many different repeater sites linked together via a microwave backbone. For example, Channel 1 is repeated at sites in Bon Air, Dinwiddie, Louisa, and Powhatan.The dispatcher can transmit on any which one they select. There are remote recievers at these locations as well as in a few others. All this guarantees that the system, ergo- the dispatcher can hear a unit if they transmit-with some degree of clarity. As with any radio network, there ARE dead spots, but if it becomes an emergency, the user may select a different channel and reach a communications center.
enjoy
/B A/
mstarn
Clover, SC
:D
Enjoy:
Ch.
Base
Mobile
CTCSS
Area Served
154.935
167.9
Richmond, south and west
2
158.985
154.905
127.3
Richmond, north and east
3
159.165
154.445
127.3
Culpeper
4
159.135
155.460
167.9
Fairfax
5
159.165
155.445
192.8
Appomattox, south
6
159.135
155.460
192.8
Appomattox, north
7
159.000
154.935
127.3
Wytheville, east / Fairfax
8
159.165
155.445
167.9
Wytheville, west
9
159.165
155.445
146.2
Chesapeake, north and east
10
159.135
155.460
127.3
Chesapeake, south and west
11
158.985
154.905
167.9
Salem, south / Culpeper
12
159.000
154.935
146.2
Salem, north
13
159.000
154.935
192.8
Melfa
14
154.680
154.680
114.8
Executive Protective Unit
None
None
154.665
None
TAC/car to car
None
None
154.695
None
Surveillance/Aircraft speed enforcement
None
None
458.350
None
Portable/Repeater/Hand Helds/Mobile Extender
None
None
39.54
None
SIRS/Statewide Mutual Aid
The State Police tend to leave the repeaters on most of the time and both the base and mobiles may be heard on the base frequency.
MOTORHEAD3902
Good listing. If I think of it, I'll try to put my hands on a map of repeater sites throughout the divisions and see if I can get it scanned. A note on VSP radio channelization, though,channel 13 is no longer used, as there is no longer a separate dispatch facility in Melfa. Area 31 is now covered on channel 9 Chesapeake. It has been this way for some time now, and the only folks you'll hear using the input combination for channel 13 are the radio techs.
But i do remember the old KIC825....
looking for a new closing catchphrase
/B A/
bl86
Greensboro, NC
Hello,
Do channels 7 & 8 (below) coverage areas overlap some on the joint I-77/I-81 stretch going through Wytheville? Where exactly does the channel 8 start covering I-81 around Wytheville? Am I correct that channel 7 covers all of I-77 from NC to WVa? Any good Wythe county sheriffs frequencies also appreciated.
7
159.000
154.935
127.3
8
159.165
155.445
167.9
Wytheville, west
Thank you,
Bry
EWTCMT
Whitetop Va
side.
Wytheville also has base repeaters on Big Walker Mountain, Whitetop Mountain,Big A Mountain, High Knob Mountain and Hunter Lookout Mtn In Lee County in the far western part. There used to be one at Beamer Knob but I am thinking it was moved. They blanket the area fairly well in SW Va anyway.
Have fun monitoring on your pass through!
Wayne
musicman
Roanoke, VA
Suggested Scanner Channel Plan
If I'm going to be driving through a large section of Virginia, I set up the scanner with each input frequency followed by the corresponding output frequency. I lock out all the output frequencies. That way, I avoid hearing about traffic situations far away. If one of the mobile (input) frequencies comes alive, I hit manual (twice) to get on the appropriate base frequency. If there's reason to keep an ear on that traffic, I would then unlock that base frequency and scan.
Of course, I'm also scanning Tac, Surveillance, and SIRS
