State Police on County Trunking
dic
Weston, FL/Swampscott MA
I notice that the database for MSP does not show where some channels are either simulcast on trunking systems or moved operations to a local trunking system. Below is a table that crosses all the ones I could find. This info should be in the database section for MSP but I don't know how to get it there. I submitted but nothing has happened.
Maryland State Police on local Trunking Systems
39.42 Waterloo Barracks A Howard County (SID=1707) Talkgroups 45776, 47344
39.40 Frederick Barracks B Frederick County (SID=582) Talkgroups 1872, 1904
39.24 Cumberland Barracks C Allegheny County (SID=4075) Talkroup 0-02-018
39.34 Bel Air Barracks D Hartford County (SID=2846) Talkgroups 36000, 36016, 36032, 36048
39.46 Salisbury Barracks E Wicomico County Public Safety (SID=1559) Talkgroups 2512, 3344
39.52 Westminster Barracks G Carroll County Public Safety (SID=381) Talkgroups 2864, 3024, 3056, 3088, 3120, 3248
39.06 La Plata Barracks H Charles County Public Safety (SID=2847) Talkgroup 18592
39.96 Easton Barracks I Upper Maryland Eastern Shore Consortium (SID=615)Talkgroup 25840
39.32 Rockville Barracks N Montgomery County (SID=2142) Talkgroups 36464, 32496
39.14 Glen Burnie Barracks P Anne Arundel County (SID=187) Talkgroups 2736, 6544
39.44 Golden Ring Barracks R Baltimore County Public Safety (SID=189) Talkgroup 8048
39.38 Leonardtown Barracks T St. Mary's County Public Safety (SID=388) Talkgroups 1041, 1042, 1043, 1044
39.28 Prince Frederick Barracks U Calvert County (SID=380) Talkgroup 2576
39.60 Berlin Barracks V Ocean City (SID=2554) Talkgroup 833 and Worchester County (SID=386) Talkgroups 833, 834
Thank you for this information, Lynn.
Could someone please clarify which of these TGs are simulcast or are they primary means of SP communication in the county?
Dic
N1XBA
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
These are all cross referenced in our wiki, of course...by barrack name, talkgroup and associated system
Md State Police - the RR Wiki
As for being the primary, it varies greatly. On the Eastern Shore, there are some that reportedly use their trunk portables a great deal more than their 39 mhz channels. They revert back to 39 mhz when they are out of range or in a poor coverage area. I understand Easton barracks does this, and there may be more.
In central Maryland, 39 mhz is still pretty heavily used, and is patched into the respective 800 system (Glen Burnie barracks, for one). There are a couple of barracks with allocations which, at least so far, seem unused (Baltimore county, for one- although with the new P25 system they have, they may be in the process of doing it). The money for trunking radios is not always easy to get due to statewide budget constraints.
The 39 mhz freqs are basically simplex, which makes it more difficult for scannists to hear them. Most multi band scanner antennas aren't resonant there, so you need to have a fairly sensitive scanner or be relatively close to hear them.
best regards..Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Yes, 39.14 was the old Annapolis barracks, closed a few years ago. I understand that it's a reserve channel now, for what use I have no idea. The chart in the wiki has this correctly
best regards..Mike
tolley
Hurlock, MD
Mike could you also add Dorchester talkgroup 37600 as being a simulcast talkgroup for MSP Easton as well? MSP units assigned in Dorchester will typically monitor the Dorchester system especially in the sourthern part of the county when they are out of range with the UESC system.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
You can do that yourself - as I've said on many occasions, this is a user maintained database - meaning you and anyone else can make the necessary changes to almost any page in the wiki
Thanks for the additional info...Mike
