State Police with new GRE-PSR 500
1dougsk
I have newly purchased a GRE PSR-500 from ScannerMaster. I had them program in the VA State Police VHF digital trunking system. Everything was programmed into Scan list 1. I would now like to try to program each Division into a separate scan list (Division 2 in scan list 2, etc.). Would I need to add control channels and tables into each scan list, as well as talkgroup ID numbers?, or would it be sufficient to just add the talkgroup ID numbers to each scan list? (I have the ARC500 software.)
Thanks very much!
mikev
Northern VA
If they programmed everything into one scan list, you can edit the existing objects in that scan list, removing them from scan list 1 and putting them into whichever other scan list(s) you want. Objects can be added to more than one scan list, so you could have one talkgroup that is in every list, if you really wanted.
Webodisk
Silent key.
Virginia Beach,VA
not really good with arc500, but you just need to check the scan lust you want the different division in no need to add control channels
