Why is the end of transmission and squelch static not so heavy as other bands? As soon as you get out of the air band, it is the same old heavy static. It is not because it is not a repeater.
Air band is AM. Nearly everything else is FM. The squelch circuits behave differently between the two modes.
On VHF static and atmospheric noise is almost nonexistent. It's not the squelch and it's not static you hear; it's random electrical noise (white noise) produced by the receiver itself, turn off the squelch and you'll hear a steady hiss. Due to the nature of AM vs. FM receiver circuitry internally generated noise sounds louder on FM.
For what it's worth, in a receiver signal to noise (S/N) ratio is more important than overall sensitivity so pay attention to published data on "quieting" levels. Just because it's sensitive you still can't hear weak signals through a lot of noise.
