status message in kenwood nx220/320
Samo84
Lebanon
Hello ,
I was trying status messaging in mu kenwood nx220 , I set on of the button to status+selcal ,
and press it then choose the station I want to send the message to , let us pretend it is ID : 1000 ,
I press then * to choose call base and press ptt to send ,
the issue that it is giving me , sendind dat , and then no reply :(
does any know know what is the issue ? and where I can add more message templates such as call base or call station or etc .
Thanks ,
Sam
ramal121
Lots and lots of watts
Calif Whine Country
Well you do not state if you are using fleetsync or nxdn however both operate basically the same.
When a sel call is sent, the receiving radio will ack back confirming it received the call. If the sending radio doesn't get the ack it will display "no reply". Could be wrong freq, ran, qt, etc., or the target radio is not set up quite right to accept the signalling. Lots to check.
The status alias are set up in the status list tab. You can have 50 for fleetsync, more I believe in nxdn.
Do you have the programming manual from Kenwood that explains how to set signalling up? It's quite a chore and everytime I do it I will need several attempts to fudge it to the way I would like it to work.
Samo84
Lebanon
Thanks a lot Ramal for your prompt reply ,
So we need to change something related to the status messaging in the configuration of NX220 , thats mean i need to use KPG141 and try this ?
Would you please guide me where i can find programming manual from Kenwood that explains how to set signalling up
Thanks a lot ,
Sami.
100pcttn
Dickson,TN
Hi Samo84, I was reading the thread on this, and just curious...you wouldn't happen to have a link to those programming manuals for my NXR-810 repeaters would you? I've got a thread running in this forum group right now trying to figure out some programming issues I have here at work.
Thanks.
