Hi!
Newbie here. I am planning to build a 6 m (20 ft) tall 42.4 x 4,0 mm (1 1/4 x 5/32") steel tube mast for the Sirio Vector 4000 antenna (height 8480 mm (27.82 ft), weight 4.7 kg (10.36 lb), wind surface 0.29 m2 (3.122 ft2), wind load / resistance is 329 N at 130 km/h . The material is S355J (A572 Grade 50 equivalent).
Mast will be fixed to a solid construction at 1.2 m (4 ft).
Is there a calculation I can use?
Is it possible to use it without a guy?
Thank you.
Thank you.
