Stevens Inst
Rufus,
They may have changed PL or frequency? I checked their FCC license data KNEL812 and they have a second low power frequency of 464.3250 They also have a second FCC license KB67357 with 5 low power UHF frequencies.
469.4125
469.4375
469.4625
469.4875
469.5125
With low power UHF frequencies you will have to be either very close by t or have a good antenna. However with a good antenna you may pick up other close by low power users licensed on the same frequencies.
Also FCC license data may show frequencies that are low power but then the licensed agency does something else.
Example; Montclair State University is licensed for 10 low power / mobile UHF frequencies under WPKE307. However, out of the 10 frequencies 2 are actually repeater out puts i.e higher power for campus police and OEM.
So a little more time and patience in monitoring the above frequencies and if you can and if your scanner can do PL/DPL search this may solve the mystery.
Once you have your revised data you then can submit it to RR.
I hope this helps
