HuubRoem said:
FYI
Hi,
AF1, SAM 29000 and SKIP 45 (E-4B) just passed NW-Europe and heading CONUS, working 05649.0 with GANDER.
SKIP 45 was heading LAGAS > CZQX
Thanks Huub. We've been following the progress of the flight through the ears (and eyes) of the European monitors and will post the arrival into our area when they get here. The SKIP 45 E-4 was noted into Andrews just prior to the start of the trip also.
So far, I've counted 19 separate monitors that logged the SKIP 45 (E-4B) aircraft this afternoon starting in Italy and going north.
There has been constant MilAir activity all day. At 1700, there is a bunch of offshore activity with Langley aircraft. Some of them are working with HUNTRESS on 288.4. One of the aircraft mentioned others assigned to 235.7 but I haven't heard anything there yet. One of the aircraft has a problem is told to RTB. Flight leader tells the aircraft with the problem to go to SOF and then come back and let him know what he says.
There is also Langley F-22A activity w/HUNTRESS on 260.9...callsign ROGUE....and DAGGER.
Missed callsign of the aircraft with the problem who is now (1706) w/Langley SOF on 383.2 asking if he should come back by himself or with a wingman. He has an oil pressure problem.
There is also Naval fighter ACM activity on the usual 365.7 at this time....callsign DOG 1 and DOG 2.
1711: DAGGER F-22A announces "Exercise (x3) and that he has sustained battle damage."...260.9
There are at least two DAGGER aircraft and one ROGUE aircraft on this freq. ROGUE is announcing a "Kill"...260.9
Between the Langley aircraft all over the place and the Naval ACM activity, the radios are just constant chat.
1713: There's a lot of chat on the Langley SOF freq again but is now too weak to copy from here...383.2
1715: Langley F-22A activity on GK's tac freq...312.3
1715: DAGGER 1 and 2 are going to RTB...so is ROGUE 1 and 2...260.9
1716: DAGGER to Giant Killer to say they are fighting on 312.3 and please stop coordinating on it...312.3
1718: DAGGER to HUNTRESS to say his flight and ROGUE will clear off...then DAGGER tells ROGUE he'll report to MAD DOG...260.9
1719: Willow Grove A-10s on interflight...142.25
1720: ROGUE 61 to HUNTRESS to report RTB in 5 minutes...260.9
1721: DAGGER turns the freq loose...312.3
1721: DAGGER on interflight freq...238.825
1721: DAGGER 01 to GK to report to Cape Charles at FL 200...249.8
1722: Willow Grove A-10s on interflight...141.725
1722: Langley F-22A activity on interflight freq...252.775
1723: Naval DOG fighters checking out an airliner...CAT also on freq...365.7
1723: ROGUE 61 to Gk for RTB through Snow Hill, TURET...249.8
1724: Langley F-22A activity on interflight freq...282.675
1726: WORLD 9894 calling McGuire Operations...134.1
1727: Italian Air Force (F900EX, MM62244, 93 Gruppo) overhead the area at FL 390...ZDC VHf
1727: DAGGER 71 flight to ZDC-Cape Charles...256.8
1728: DAGGER 71 "Push 5" which is Norfolk TRACON (East) and check in there...370.925
Someone flipped the switch at 1730 and it got suddenly quiet.
1731: DOG and CAT ready for another go...getting BRA of target...and off on the chase they go...365.7
1733: Langley fighter activity on HUNTRESS freq...235.9 (DAGGER must have made a mistake earlier when he said 235.7...he must have meant this 235.9 freq)
1735: Willow Grove A-10s with Philadelphia TRACON...291.7
1735: u/I w/Willow Grove mentions R-5802 (Bollen Range)....266.8
1735: E-6B, 163918, VQ-4 climbing out from Patuxent...still in initial climb on course 200 degrees...310.15
1738: Our E-6B is turning to the west and is up to 15,000 feet...continuing the turn to the northwest to 305 degrees...310.15
1740: ____ 21 [female] report RTB to Giant Killer...239.8 (listening for the E-6 and missed the callsign)
1743: DOGs and CATs and BONEs and whomever else is working that Navy 365.7 freq says they should call it quits...and do...365.7 (More than likely these guys are out of Patuxent)
1744: Caught our E-6B w/ZDC-Brooke 126.875...his suffix is 92...handed to ZDC-Tech 134.625 and reports at FL 332, climbing to FL 340...he's also on a westerly course again 270 degrees. If he continues this course, he's going to pass Gordonsville about 10 miles north of it rather than the usual few miles south of it.
1747: DELTA 70 w/Giant Killer...135.725 (No idea who that is...could be commercial but don't know why he'd use that freq...commercial usually use 118.125 for Giant Killer)
1747: U/I A-10s w/Harrisburg A/D...281.525 (Same aircraft on interflight 141.725)
1749: DC 33 (KC-135R, 58-0075, 756th ARS Andrews) working the pattern at ADW...118.4
1751: Bollen Range active with A-10s...237.2
1752-54: U/I fighters with ZNY-Swissdale...279.55
Sorry I missed all those Willow Grove callsigns. I just couldn't stay on one of their freqs long enough to listen for them. Some are still at Bollen Range at 1800.
Guess someone rang the chow bell at Langley because all their flights went home by 1730.
1804: BATON 55 (EC-130J, 01-1935, 193rd SOW PA-ANG Harrisburg) calls BATON Command or BATON Control...25 minutes out, 23K on the fuel, A-2...the writeup is "Program tech, no video on the monitor"...395.1
1805: It's an UGLY flight of Willow Grove A-10s at Bollen Range...237.2
1809: DC 33 tells ADW Tower they just got word their receiver is now ready so they'll complete this approach and then want their IFR clearance out of there...118.4
1826: U/I groundstation working DC-ANG SOF freq 139.9...high level of echo in the voice which makes him unreadable.
1828: UGLY to Bollen Range controller BALKY...sounds like they're getting ready to leave the range...237.2
1829: FLYER flight of two Willow Grove A-10s now w/BALKY for work at the range...237.2
1831: PITT 11 (C-130H, 787-0811, 758th AS AFRC Pittsburgh) calling Norfolk ASOC...says he's a C-130 and is 15 minutes out...says they're taking off right after they download...349.5
1833: DC 33 with LIBERATOR...mentions several problems aboard the aircraft...says they're going to get in the pattern again...wants LIBERATOR to let McGuire know they won't be coming...378.1
1835: Have a C-5B, 87-0036 from the 60th AMW Travis in the area (Don't know which freq he was on or even which radio or console the transmission came from)
1837: ROMAN 25 (F/A-18, VFA-106, NAS Oceana) w/ZDC-Salisbury...257.7
1838: DC 33 to LIBERATOR wants them to call maintenance to see if they've got anybody that can actually work on their problem tonight. If so, they'll just bring the aircraft in for a full stop...while on the way to the track, they lost pressure on the primary oxygen system...changed to secondary system and pressure leveled but then they completely lost the system...378.1
1843: DC 33 reports 15 minutes out, 46K on the fuel...will do a full stop...gets Spot-3 for parking...378.1
1848: DC 33 w/TRACON on approach to Andrews...128.35
1848: Air Force 1 (VC-25A, 82-8000, 1st AS Andrews) just passed over Cape Cod on his way back to Andrews. We should hear him in this area in about 30 minutes.
1851: AR freq active...235.1 (AR-206/AR-328)
[Mark, this is same tanker callsign we were trying to figure out on that recording you had - the one that isn't BORA.]
1853: SAM 29000 (VC-25A, 92-9000, 1st AS Andrews) over Cape Cod and heading this way.
1857: REACH 9505 (KC-135R, 59-1505, 151st ARS TN-ANG McGhee-Tyson)) overhead the area at FL 350...ZDC VHF
1905: SKIP 45 (E-4B, 75-0125, 1st ACCS) also in the area...ZDC or ZNY VHF (Has been with the Presidential fleet for the trip)
1906: Air Force 1 w/ZDC-Sea Isle...133.125
1912: AF 1 descending to FL 200...133.125
1913: AF 1 cleared to FL 180...reports passing 210 for 180...133.125
Andrews: AIR TERMINAL RAMP FREEZE. 17 JAN 00:35 2008 UNTIL 17 JAN 01:05 2008. CREATED: 15 JAN 22:06 2008
1916: AF 1 handed to ZDC-Casino and checks in at FL 190 heading for 180, has information Whiskey (ATIS)...127.7
1917: AF 1 cleared to 14,000 feet...127.7
And then my phone rang...if he changed freqs in the past minute, I missed it.
1925: AF 1 still on approach...down to 11,000 feet.
1927: Andrews CP Ground Controller announcing ramp freeze in effect...141.55
1929: AF 1 w/TRACON on approach to ADW....128.35
1930: AF 1 turning to 280 and in the descent to 3000 feet...128.35
1932: AF 1 cleared visual approach to runway 1L...128.35
1933: AF 1 to ADW Tower for runway 1L, gear down...cleared to land...118.4
1935: And AF 1 is on the ground...118.4
1945: SAM 29000 (VC-25A, 92-9000, 1st AS Andrews) to 3000 feet for runway 1L at ADW...heading 250...reducing speed to 190 knots...128.35
1950: SAM 29000 told to maintain 3000 feet...128.35
1951: SAM 29000 cleared for the visual to runway 1L...128.35
1952: SAM 29000 handed to ADW Tower...visual 1L...cleared to land 1L...118.4
SKIP 45 did not land here. I believe he's going straight to Offutt.
While I was listening to the Presidential fleet coming home, BATON 55 (EC-130J, 01-1935) departed Harrisburg again. I heard him with ZDC-Casino on 127.7 asking which freq he should use for Giant Killer. That was at 1928. A minute later he called Giant Killer on 135.225 to enter W-107 for mission A-1705. Strange that he had to ask since that aircraft goes often to W-107 and always knows the correct freq is 255.0. He must've been a newbie. He wanted the altitude block 16-17000. By the way, the correct VHF entry freq for W-107 is 135.725. The 135.225 freq he was given is for W-105.
2004: PITT 11 calling Andrews Command Post...no joy...378.1 (This is the aircraft I logged going into Norfolk at 1831 above)
2009: BATON 55 now with Giant Killer on correct freq...255.0
2009: PITT 11 (C-130H, 78-0811, 758th AS AFRC Pittsburgh) to Andrews CP says he's delivering a propeller for the aircraft in 11-Row and would like to park next to it if possible...gives his tail as 78-0811...378.1
Ref Below: JR, I also thought I heard FLORA 92 for his callsign. I didn't print it since I wasn't sure of it but, apparently, you heard it just as I did. I didn't get him unti lthe Brooke Sector 126.875 and then to Tech Sector and lost him from there. They don't seem to want to say the destination in those clearance messages. They just use "as filed." We did get the one going to Bermuda that day though. Perhaps YUCCA (as in the desert tree?) for the backend callsign???
Edit: OKay...I was just guessing at something close to what you first had...obviously, I didn't hear it from here.
NOTE: Tomorrow I'm going to try to get a good picture of the Guard Dog CAP on the Center map I have and will post it here. Last week I used one of those maps as background for pictures of some radios I sold and posted a piece of it and it looked pretty clear. It should give a good representation of the limits of the CAP area although I think I've described it so many times here over the past year that everyone has it set to memory.
Yet another NOTE: The 108th ARW at McGuire got its first KC-135 'R' model. It flew through this area this evening as TOPCAT 3. The old unit for that aircraft was the 22nd ARW in Kansas. Actually, this may not be the first but it's the first confirmation the 'R' models are now flowing into the 108th. I know they are to get at least eight of them and eight of the 'E' models will be retired.
