Sticky Thread for MilAir
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I have no idea where you found that the ScanTenna doesn't work well on milair- I've seen comments saying the exact opposite. Making sure you feed the antenna - any antenna - with a good grade of coax is vital, particularly when you are up near 400 mhz. The higher the frequency the more the coax construction becomes critical. Loss is never fun. I've seen enough comments that the ScanTenna's performance does fall off at 800 to think that might be a fact. I have a ScanTenna clone in my attic, attached to an amp that goes into my 2004 - works very well.
Several folks I know use Discones - specifically the Diamond, and one or two have the Icom model. DPD productions also makes 2 milair antennas, if memory serves - one for just the 225-400 range, the other for that and the 138-144 mhz range. Our Scanner Antennas Wiki has many such links. If you've got a good hand for working with piping, many seem to have found the Off Center fed dipole works well here, too - this is a homebrew knockoff of something Grove has been selling for some time. (just click on the blue text - that's a link)
As for the BCT15 - interestingly there was a review of the 15 in a past MT by Larry Van Horn who liked the 15's performance on milair. Keep in mind that it won't do digital trunking - if that's important in your area, then give that one a pass (unless you're going to dedicate a scanner to milair - many do that, too).
73s Mike
adkad
Pat199 off of Buckley at 6:45 AM. Pat is listed as US Army Priority Air Transport (Andrews AFB). Adkad
abqscan
DataBase Administrator
Moderator
AOA
0900, Stud-31, flight of 2, take off BKF, 291.675>251.075>317.550.
0915, Redeye-11, flight of 2, direct pueblo, told center that for the last two day, their comm's were poor and can hear everyone else fine on UHF, so it must be a center problem. Flew to Cheyenne MOA.
0945, Bobcat-32, (T-45C) inbound to BKF, requested a couple of ILS's before full stop.
1010, Redeye-21, land BKF.
1015, Redeye-11, land BKF.
1023, Stud-21, land BKF.
1024, Taco's are playing at Airburst, 251.250.
adkad
redeye11 flight of two off at 9:03 from Buckley
redeye21 flight of 3 off a few minutes later
redeye 21 pointed out there were some communication problems on 379.50
adkad
manross
Thanks adkad,
I'm on lunch typing this. My department is sending me to these dang ICS classes. I guess the fact that I may retire in a couple months doesn't make a difference to them :) Anyhow I read it on a forum somewhere that was talking MilAir antenna stuff. Up to this point everything that I had read was also positive. I read so much the last few days my head is spinning. I was already to buy the Scantenna, then read that thread, then here I go again....wondering!!!! I'm glad to hear that the BCT15 does well on MilAir. Which ever scanner I end up with will be strictly dedicated to MilAir/Air band only. I have a Pro96 and a 2096 for the trunking stuff around here. Already have an antenna for those so the antenna will actually be dedicated to the air stuff too.
I do appreciate you taking the time to answer some of my questions. It sure helps trying to avoid un-needed mistakes in equipment buying...
Thanks again,
Marty
abqscan
Moderator
AOA
1325, Unknown C/S calling Denver Radio FSS, 255.400, said they were 30 miles east of Kremmling.
abqscan
Moderator
AOA
Redeye-51, flight of 4 F-16's, take off round robin, direct Pueblo. Landed a little after one.
1335: Josa-425, calling Peterson dispatch on 372.2.
abqscan
Moderator
AOA
Pat-777 inbound to BKF, advised tower that they were not recieving any DME from BKF. Says it might be ice on the antenna.
abqscan
Moderator
AOA
1126, PAPPY-1, (F-15, OR-ANG), inbound to BKF using the QUAIL FIVE arival. 381.5>251.075>291.675
adkad
not much activity lately:
10:00 AM redeye 11 a flight of four off from Buckley.
SUMMIT 20 C-130 731 AS/302 AW PETERSON AFB CO. departed Willow Grove NAS about 20 minutes ago with Command Post 351.7500.
Also heard SUMMIT 16 into WG Sunday.
May be working their way back to Colorado..
Also good A-10 pics today on Maryland board from last Month at Warren Grove range in Jersey..
http://www.radioreference.com/forums/showthread.php?t=44841&page=83
Maryland
abqscan
Moderator
AOA
The Redeye-11 flight is out at the Cheyenne MOA.
1036, Redeye-91 inbound to BKF, he is a single ship. The other 3 F-16's came in yesterday afternoon. Unknown why one was left behind.
1111, Taco 11, flight of 2, practicing high deliveries at Airburst. 138.85 and 251.25 are in use.
1125, Redeye-11, land BKF.
adkad
Redeye11 a flight of 4 broke into two groups-scud31 and 32 landed at 11:25, while redeye 13 and 14 became redeye 11 and practiced low approaches
cap?flight 571followed redeye11 in to runway 32 at 11.42
abqscan
Moderator
AOA
adkad said:
scud31 and 32
The callsign is STUD.
adkad said:
32cap?flight
The CAP flight was a tiny cessna 172 :D
Redeye 92 and 93 also landed about an hour apart from each other. The 9X #'s are used when they go TDY, or special flights.
abqscan
Moderator
AOA
1332, Stud-61, flight of 2, on the weeds transition. 251.075>317.55.
1335, Redeye-41, flight of 4, direct pueblo, 251.075>379.95(took a couple of try's, nobody was home)>387.15.
adkad
sorry-of course it's stud. I wondered what the cap flight was-the atc guy at Buckley told him if he hurried up he could land in formation with Redeye11. The pilot just laughed. Adkad
abqscan
Moderator
AOA
1453, Redeye-93, Single ship straigh out on the VR-413, 251.075>255.4.
1456, Stud-61 flight, inbound.
1457, Redeye-11 flight inbound. A bunch of write ups.
adkad
stud 61 a flight of two and redeye 11 a flight of 4. Helicopter 600 was cleared by
Buckley clearance but told the firing range was hot. Adkad
abqscan
Moderator
AOA
Taco-61, flight of 2, operating at Airburst on 251.25, and 140.725 for A/A.
abqscan
Moderator
AOA
2035, Pat-673 in bound BKF 121.0.
2036, Josa-092, inbound COS with 6 PAX to offload. 372.2
2047, Guard Chopper 600 inbound BKF.
