stock moto cp200 freq
sycobiker2
staten island ny
my job just picked up a bunch of cp200 model# aah50sdc9aa1an 4ch uhf i am guessing. does anyone know the stock freq and pl if there not csq. we are short radios so if i can ill use my own xts 2500.
any help is awesome
jruta
Nj
Not sure what you mean by "stock" frequencies, as the radio is frequency programmable within it's band range. And yes, you can use your xts (assuming it's the same band) with the cp radios. The radios would have to be read via cps to determine what frequencies, and PL are currently in them, if any.
What he means is, what is the freq of Channel One, as programmed in the radio from the factory.
jruta
Nj
Yep, No way to know unless read via cps. I don't know any other way to find that info out.
J
Skypilot007
Medford, NJ
J
If you have a uniden scanner with close call function you could simply start transmitting with the cp200 in question and the uniden scanner will find the frequency and pl/dpl tone in a few seconds. Or an optoelectrons unit will do the trick also minus the tones.
jruta
Nj
True, didn't think of that.
J
