Story County Status
mdcory
Fleet mapping won't be done until the end of August. Guess we'll know more then. I just hope they don't decide to encrypt anything.
mdcory
I have a BCD996P2 and only have the Collins and Ames towers programed in with Ames and Story County talk groups. I haven't changed any programming in it for a long time. This past week or so I have noticed that after some traffic has end from either dispatch or a unit and the scanner is still within the delay I am picking up traffic from other agencies. Like just a few minutes ago dispatch unkeyed and right after that I heard a Jasper County unit clear a traffic stop and asked to be put on the Newton fire. I have used a scanner for a long time but admittedly don't know all the ends and outs. Is this just a weakness of the scanner and the simulcasting? I figured I would ask here to see if anyone else was having the same problem since the system they are running is still a temporary setup.
thatoneiowan
Iowa
I think the Collins site carries traffic for Marshalltown and Jasper counties and maybe Polk too. You'd probably want to lock out those talk groups or delete them from your programming if you don't want to listen to them, or just scan the Ames site.
mdcory
The Collins tower does have Marshall and Jasper, but I am also getting the "bleed" from the Ames tower. It doesn't happen all the time but this past week seems a little more often then usual. I only have the Story County talk groups programmed. I have both Ames and Collins towers programmed because it depends on weather and everything else where I get better reception from. Can't wait until the new tower 3 miles from me is live.
thatoneiowan
Iowa
Gotcha, no I haven't noticed anything weird off the Ames site but I only listen intermittently. I'll keep an eye out for it
watchtower6
HAM Land
Sounds like the switchover took place to new talk groups. So far Ames Fire Ops1 is 48503. Unconfirmed is 28508 as the old APD Parking Ops3 and unconfirmed APD on 28502. Slow at night so hard to confirm. Heard the County talking on the old channels and Sheriff Dispatch advised them to use the new channels but have not them yet with new talk group IDs. Both the Ames site 800 and Wallace Hall 700Mhz sites seem active.
N0ZJT
Oelwein, Iowa
I just entered a new site that I've been decoding for about the last week when bands are open. It's using some of the same frequencies as the Wallace Hall site, just a different RFSS, Site ID, and NAC. It appears the Wallace Hall site is now only using 771.09375 and 771.50625.
This morning bands are open for me to listen to it with DSD+, here are my notes:
28501 - Story Co Law Dispatch (previously 58592)
38525 - Cy-Ride (was 58557)
38526 - Cy-Ride Admin (was 58558)
28509 - ISU PD Dispatch (was 58573)
28502 - Story Co Law 2? (was 58593)
48502 - Story Co Fire Paging (was 58584)
28505 - Encrypted - might be Ames PD...Heard a unit on old Ames PD TG 58569 asking for a radio check, then saw traffic on 28505 on the new system.
If any of you guys closer could confirm this, I'd appreciate it.
MCWKen
Clinton, IA
Maybe I mis-read this thread, but how is a Window's based software decoding P25 Phase II TDMA?
And why would anyone want to go to SARA when there is state-wide coverage with ISICS?
thatoneiowan
Iowa
Encryption on 28505..... And a correction not sure about the Ames 800Mhz site being used.
Fwiw my Ames/Story County feed got a no audio report and the only tower I send was the 800mhz Ames site. They said they only heard I think Mary Greeley ambulance. I won't be able to even look at it until tonight or tomorrow.
I also feed the Ames site to Calls and starting yesterday or the day before I've been getting hit with a lot of emails saying node offline/online/offline/online.
Does anyone know if the radio IDs/unit IDs are the same or have those changed as well?
watchtower6
HAM Land
Today I'm not receiving anything from the 800Mhz. I'm only receiving the 700Mhz off Wallace Tower. Talk group IDs have changed. Combined with the info N0ZJT added so far we have:
28501 Story Law 1
28502 Story LEA
28505 Encrypted
28507 Encrypted
28508 Ames PD Parking3
28509 ISU PD
28511 Encrypted
28525 Encrypted
48501 Story County Fire Ops1
48502 Story County Fire Paging
48503 Ames Fire Ops 1
38525 CyRide
38526 CyRide Admin
Not confirmed are some 385** groups that seem to be ISU Maint and 585** that are Public Works.
Possibly 58501 Story Secondary Roads but not confirmed.
mdcory
By the signal strength I am getting with the tower N0ZJT added I am guessing it is the one at 620th ave and 305th st. It's just a couple miles west of me. Getting nearly double the strength I was from the Collins tower.
signal703
because SARA is dense simulcast with in-building, portable, on hip coverage to about 95-98%
thatoneiowan
Iowa
48513 possibly Mary Greeley paging for Ames. They responded on 48503. I also agree with the below
28501 Story Law 1
28502 Story LEA
28509 ISU PD
38525 CyRide
watchtower6
HAM Land
North of Ames the only control channel that I can use is the 769.09375 wherever it is and it makes use of all the old channels for talk groups. I can't copy anything on the 2 channel system. Maybe its aimed in a different direction from me.
thatoneiowan
Iowa
28510 is ISU something... I just sat down and they were saying something about assisting someone with a flat tire. ISU Parking? ISU Help Van? Are those the same people?
I also just started a Calls node for the site; this took offline my Ames site node (I was getting spammed with online/offline notifications anyways). I don't remember who all has access to the unidentified TGIDs but I'm streaming everything that SDRTrunk will pick up in Huxley.
thatoneiowan
Iowa
I went through some of my Calls recordings and this is what I've found. I haven't submitted any of these to the db as I'm not 100pct sure on them.
I marked * as ones that look to match @mdcory's google doc
*85 - Cambridge FD Chat (low confidence)28504
*85 - Collins FD Chat38505
85 - Story City First Responders Chat (not sure if separate from FD)38514
*Ames Fire Tac 148508
*Ames Mary Greeley EMS Operations48504
Ames Traffic Engineering (low confidence)58526
ISICS IA Tac 214067
ISICS IA Tac 265176
ISICS R1 Call 11 (low confidence)64904
ISICS R1 Tac 1664908
*ISU Dept of Residence Service Center38529
*ISU Unknown Maintenance38535
ISU PD Info/ISU PD Law Tac 2 (referred to as both names)28520
ISU PD Ops 228510
ISU Security/ISU "Command" (not sure if these are the same thing?)38520
NWS DMX MICRN37711
VLAW31 Patch18502
TJK50010
Texas City / Galveston TX
I still need to get up to Ames. Play with my SDR a little. Sounds like a mess.
I noticed that Ames dispatch is in the database as TE. Did they go full channel encrypted?
