Hi Everybody, I am in the NE of England and using the R8600. I set it up to do a Program Scan on the 2 Mtr band as follows 144Mhz to 146Mhz, FM, Filter 2 and 12.5k TS and when I start the scan all of those parameters are loaded in and the scan works as expected. However if I stop the scan and change the Mode, Filter or Tuning step manually to different values and then restart the scan it will retain those manual settings even though the original settings are stored in the scan memory. If I exit the scan and start the scan again the manual settings remain., but if I change the mode, filter,ts and move the frequency outside of the 144-146 Mhz range and restart the scan then all the programed settings are restored. Is this a firmware bug or is it doing what its supposed to do. Thanks Take Care.
