Strange Squawking Sound - G5
bob550
Albany County, NY
We're straying a bit from the topic Unication, and are likely to get told to stop by our friendly mods
Perhaps. But you're contributing to the knowledge base of the OP who is trying to understand the nature of the issue he is experiencing. :)
boatbod
Talbot Co, MD
The repeater system or the receiver are failing to recognize the end of transmission bits and try to process random noise as voice.
I just can't see that happening in the receiver as there is too much error correction passed in the P25 protocol stream for random data to be validated as voice. More likely it's noise (or something else) being encoded into AMBE codewords at the base station.
bob550
Albany County, NY
Lately, I've heard a similar noise which sounds more distant, as if it's background noise being re-transmitted along with the audio on the transmission I'm monitoring at that point. It occurs infrequently, and I haven't discovered any correlation between the talkgroups this occurs on and the one's I've experienced this on.
RFI-EMI-GUY
If you break the transmission before the receiver sees the TDU, the receiver is going to try and ride out a few random bits (assuming a faded condition) until it mutes. This could happen anywhere in the system.
boatbod
Talbot Co, MD
Not it really couldn't because a P25 frame either contains valid a LDU1/LDU2 or 2V/4V or it doesn't. Fade, random bits, and pure fantasy simply don't get passed along to the AMBE codec.
RFI-EMI-GUY
If that were entirely true, you would never receive garbled P25, yet it happens. I guess I am going to have to try some experiments for you.
N6ML
I think he's saying that a frame could contain some uncorrectable (sp?) errors (so you can get garble during a message), but there should never be an LDU frame after a TDU, so there shouldn't be any voice data to even try to decode at that point.
I wonder if it could be a frame belonging to a different (new) session, on the same voice channel, though? Don't know if there's any verification of each frame to ensure that it pertains to the message being received.
RFI-EMI-GUY
If you go back to what I suggested, I said that
"The repeater system or the receiver are failing to recognize the end of transmission bits (aka TDU) and try to process random noise as voice." ,
meaning the TDU is being dropped by some element of the system and the receiver is trying to process random stuff. The random stuff of course is uncorrectable and the receiver is going to let some of that happen for a period of time until either it sees a TDU or some valid voice frames otherwise completely mute and start over..
boatbod
Talbot Co, MD
Experiment away, but I'm telling you from a protocol standpoint your hypothesis that random data can be mistaken for AMBE codewords is just not possible. Clearly you shouldn't take my word for it, but go read TIA-102 (as I have done for many hours while working on op25) and understand how the numerous layers of FEC are applied to their respective payloads, then tell me how the firmware in the receiver could even begin to think it has valid data that should be sent for playback.
Garbled playback happens very rarely on a subscriber radio because they have better demodulators and first class FEC handling. At the opposite end of the spectrum, traditional consumer scanners do a horrible job and spit out garbled audio frequently because the do the least well at demodulating the signals and spend little to no effort on FEC handling. Somewhere in the middle are the various SDR packaged (DSD+, OP25, Trunk Recorder,...) and products like the Unication G-series pagers which make an honest effort to get things decoded properly. When garbled audio does work through those devices, it is either the result of the frame having bit errors in the non-error checked portion of the codewords, or attempting to play back encrypted traffic as if it were unencrypted. It is also possible under marginal signal conditions for frames to only successfully being decoded intermittently, leaving the failed frames in between to be either muted or excessively frame-repeated using prior good data.
