Thanks for the response, Jack. Let me see now if I can remember the basic steps that I have taken thus far.
1. Started off by simply installing the weather radio scripts linked to previously, changing the frequency to my local uhf freq. the weather radio is a continuous broadcast, so requires no squelch. I ran mine without squelch until i found a good gain setting. I am currently using 48, maximum is about 50. Lower settings make the feed very noisy.
2. Once I found a gain setting, then added squelch and found around 70 as being good. All this setup was done utilizing a darkice stream to a local icecast server on the pi. At this point, I was getting good but choppy audio and the darkice connection remained solid (through pulseaudio) with no dropped connections. Strangely enough, the darkice connection stays connected even when I shut the stick down to make adjustments.
3. So now I had good but choppy audio. After experimenting with just about every setting in rtl_fm and sox/play i finally found that the choppines was from alsa underruns in sox/play. Google shows lots of posts about this, but I never found one that said “do this to fix it”. I believe that what i found that corrected things was installing the -E pad option (note that everything to this point did not use the ePad or the -E dc options). Of course, to make this work, I had to go back and install the keenerd fork of rtl_sdr as the one that comes with the weather radio setup does not include the -E pad option.
4. Then i was getting some bleed-over from an adjacent frequency so I had to narrow the band that the stick was listening to, reducing it to 250 kHz
I think that is the basic synopsis. The code that starts it now is:
rtl_fm -f 460.400M -s 48000 -p 55 -g 48.4 -l 73 -E dc -E pad | play -r 48000 -t raw -e s -b 16 -c 1 -V1 -v 2 - sinc -3.5k
Thanks for all the bits and pieces in your previous post. They are what has gotten me to this point.
The thing that I have found most notable is that the darkice stream to icecast or BCFY seems to work without any dropped connections.
