strideberg HF multi coupler
C
comsec1
Guest
Does anyone use one of these for their HF listening posts, I was thinking of getting the MCA104 to use my wellbrook loop on more than one radio receiver. Thank You in advance.
C
comsec1
Guest
Thanks for the reply, Do you notice any signal loss using the passive model. I use my receivers for utility monitoring so signals are usually weak.
THanks
margetts
East Salt Lake City, Utah
Hi... I use the multicoupler with the Drake receivers & the loop mounted on a rotator. The coax feedline RG8x is approx. 125'. The signal loss is negligible; very pleased with the Stridebegh's quality & construction.
