CorwinScansNM
Hi everyone here reading this interesting situation that I am seeing & experiencing with my brand new Stridsberg FM Notch filter FLT201A. I just installed this FM Notch Filter on my Uniden Digital Scanner to try to eliminate all FM Broadcast Signals coming in to my Scanner to help with interference issues on my VHF & UHF programed Frequencies & Band Ranges. After I received this FM Notch Filter today & installed it inside on my LMR400 Coax Cable that goes into my Uniden Digital Scanner from my External Scanner Antenna and then hooked it up to the BNC port on the back on my Scanner, I did a simple no brainer Test to see if the Stridsberg FM Notch filter FLT201A was actually filtering out FM Broadcast Signals from 88 MHz to 108 MHz as I had intended that it should & was supposed to by selecting (Service Search) and then the (FM Broadcast) on my Uniden Digital Scanner?
The results were shocking & looking to be a absolute failure for the specified use/purpose of filtering out the FM Broadcasts of 88 MHz to 108 MHz on my Scanner. This because right away after selecting the FM Broadcast Service Search on my Scanner, it quickly & easily started receiving all FM Radio Broadcast Stations in my area at 3 & 5 Bars of signal receiving coverage & is clearly not at all filtering any of them out or stopping my Digital Scanner from receiving or picking them up?
Now that right there does not seem right to me nor, does it appear that the just installed Stridsberg FM Notch filter FLT201A is even 1% filtering out any of the FM Broadcast Signals to my Uniden Digital Scanner being that I can receive them all at 3 & 5 Signal Bars upon doing an easy & simple no brainer Service Search for (FM Broadcast) directly on my Scanner to test & realize this possible Product fault. Therefore, I am not sure what is wrong or going on here? Maybe I clearly received a non functional or defective Stridsberg FM Notch filter FLT201A that is going to do absolutely nothing on my end for filtering out the 88 MHz to 108 MHz like it is supposed to for $98.00 + $17.00 S&H...
