I would like to build a legal limit dummy load using two 800 watt 100 ohm stripline resistors in parallel.
I would like it to cover from hf through 70 cm.
I have attached files showing what I will be mounting the resistors on.
The heatsink is 10x16 with 2.5 inch fins an a .25 inch copper plate.
Can I cut the heatsink in half and still have adequate heat dissipation?
Is this feasible or should I look elsewhere?
