mmiller7
Has anyone else had problems with RFI from cheap Chinese goods?
I'm currently having issues with an "Auto-VOX A118 B40" car dash cam which is destroying 2M ham/business bands within 20-30 feet of my car. A ferrite choke reduced noise to about S2 on all but one frequency (148.510 per my FT-8800) which is still S7 noise out about 10-15 feet from the car and causes slight interference with the ham band when operating weak-signals (local repeater fringe coverage near my office goes from choppy but copyable to unreadable). I'd really like to make this work but I'm running out of ideas of what to do.
I have a RF-Explorer spectrum analyzer and used a SMA-to-PL259 adapter as a "probe" to isolate where the noise is, that seems to suggest the noise is coming out of the camera's plastic case (even on battery power) at a low level maybe -85dbm at 1-2 inches away and then being broadcast stronger along the USB power cord reading -80dbm at 1-2 inches away peak on the graph. The ferrite choke at the camera plug helped eliminate broadband noise (3 turns thru) but didn't eliminate it.
(EDIT: I'm certain it's the camera, I can reproduce the nose starting when it's powered on and going away when it's powered off very reliably)
Any suggestions?
Is there any standard I can cite or use for acceptable RFI at a certain distance?
Has anyone ever tried to argue getting a product exchanged due to RFI when the seller argues that it appears to function as-advertised (it turns on, records and appears to operate properly, just generates what I believe is excessive harmful interference)?
Am I being unreasonable expecting no interference with an antenna <20 feet away from a device which is not supposed to be an intentional radiator?
Any suggestions?
