Eugene
Greetings. First to any Moderator, I am cross-posting this as I think I have the Virginia Forum stumped on this so I am hoping a more general tech forum might be the appropriate place to post this question. Thank you.
While in Richmond. VA, they had a 2 alarm high rise fire in the city. I listened to Richmond fire but heard nothing. I had 4 bars signal strength and was close enough to see the smoke. In analyze mode, had full deflection on the "S" bar but zero on the "Q" and "A" bars. I have heard Richmond in the past, although you had to be close to the city, but never this. I rechecked talk groups and they appeared correct. Also as far as I know, RFD is NOT encrypted, So...….??
I have a through-the-glass TRAM antenna hooked up to a pre-amp which seems to work well otherwise. I know the through the glass antenna isn't ideal but it works well enough with the pre-amp. Was hearing Henrico and Hanover counties with no problem. Thanks in advance.
Eugene KG4AVE
Eugene KG4AVE
