I'll try to keep this short.
My system:
SDS-200 (1.24.00 Main, 1.03.15 Sub firmware)
Shielded 25' CAT6 cable from the SDS-200 to a GS-105 Ethernet switch
Unshielded 10' CAT6 cable from the GS-105 to my TP-LINK AX1800 WiFi 6 router.
Unshielded 1' CAT5 cable from the AX1800 to my cable modem.
Samsung Galaxy cellphone.
Registered user of Proscan version 24.5
The Web Server works fine. I can see & hear everything on my desktop computer that's running Proscan AND when I connect to the external IP address when I'm away from home.
HOWEVER....
I have a specific problem that only shows up on my cellphone when I connect to the SDS-200's Web Server.
It happens BOTH when I connect within my internal network http://192.168.x.x:5000 and when I connect via cell towers http://98.xxx.xxx.xxx:5000
I just realized I haven't checked if I connect to the external IP address of the Web Server from my house. Ah well.
The problem is that when I press on a key (such as, but not limited to, 'System' in this example screenshot), it stays depressed. The radio itself continues to run normally as if the key was never pressed. Repeated taps of that button eventually seems to work most of the time such that the radio does what it's supposed to do and the button will appear in its unpressed state.
I did some searching via AI and found a few suggestions there. I did some of them (new CAT6 cable, new Ethernet switch), but the problem still is present.
This 'not seeing the key go back to the 'unpressed state after clicking on it' doesn't happen when I click on the key from the Proscan program running on my PC. It only happens when I connect to my scanner's web server.
Anybody else run across this? Anybody have any ideas on what I might try? I'm not sure what I'm missing. One of the AI things I read said that Proscan had options in the on the Web Server tab that I could tweak (see attached screenshot). Apparently, those are no longer available or maybe the buttons have moved. Aside from that, I love the flexibility that the Proscan Webserver gives me.
My system:
HOWEVER....
