gdsteele
- Joined
- Nov 11, 2004
- Messages
- 80
I downloaded a modified mission plan to my XG-100m with a CH100 head. The only thing modified was the frequency of a 2M simplex channel. After I did the download, the radio comes up on the first channel of the first zone programmed, but the channel selector and the touch screen buttons do nothing. I tried downloading the original mission plan, but the radio doesn't do anything when RPM14 tries to communicate over USB. RPM says "Initializing" and then goes away. When I try to use the serial port on the radio, RPM can't communicate with the radio and tells me to check the port settings and wiring. I have tried using a null modem on the serial cable as well with no luck.
The power switch when turned off takes a good 10 seconds to turn off the radio. I have tried unplugging the radio from the power supply for a couple of hours, and no luck with that either.
Does anyone know of a way to force a radio reboot, or a radio reset to factory settings?
Thanks,
Jerry
Thanks,
Jerry
