Stuck
hcdavis
Ontario, Canada
I am using FreeScan software to imput frequencies into a Uniden BCT996T scanner. I am communicating with the scanner but when I go to the screen to import from Radio Reference I receive an error. It is asking me to check my account status, that is fine and my internet connection is fine. Any help would be appreciated.
UPMan
Uniden Representative
Arlington, TX
Make sure you are using the latest version of Freescan and make sure you have correctly entered your RadioReference login credentials in Freescan.
hcdavis
Ontario, Canada
I have the up to date version of Freescan and I checked the username and password directly to RR and I can log in with no problems. When I try the import I get the following message: Error retrieving data rom RR. Verify hyour internet connection etc.
Client found repsonse type 'text/html', but xepected 'text/xml'.
Then there is a full page of computer programming errors.
UPMan
Arlington, TX
Ok, that is either a Freescan configuration error or a problem at RRDB. I'll have to let someone else step in to assist...out of my realm of knowledge.
cpuerror
Ontario, Canada
You may have firewall software blocking access. Also if you are using one of those USB Internet connections that goes over the cell phone network, sometimes that can cause some problems as well. Beyond that though, if you could post a screen shot of the offending error message that would help shed some light as well.
cpuerror
Ontario, Canada
Looks like it might be something to do with the local machine or ISP. From what I can gather from that, there is a caching server at the ISP that is turning down the request. Might try a different computer or ISP.Maybe you have a neighber with an open wifi that you can borrow (after asking permission ofcourse).
