Stuff to listen to with a triple trunking scanner
zman099
What good to listen to with a triple trunking scanner in southern cali? Around the orange county area
madnachos
So California
The OrCo TRS, Camp Pendleton TRS, Disneyland TRS, etc. Actually quite a few systems that you can monitor from OC if you have a good antenna.
hotdjdave
K9DJW - Senior Member
The Valley (SFV), Los Angeles, CA
LA Metro
Check out these RR Database pages:
Orange County, CA
Los Angeles Metro Area
Los Angeles County, CA
San Diego County, CA
San Bernadino County, CA
Riverside County, CA
The Los Angeles Metro Area (the second one above) covers most of these areas (except San Diego County). If you are in the southern part of Orange County, then you will hear some of the northern San Diego County stuff. Click on the link to the map below:
mapserv
Ohio
Is it Analog Only or is it Digital and Analog Capable?
Triple Trunking Radio Scanner? That depends. Is it Analog Only or is it Digital and Analog capable? Also check out the http://www.radioreference.com databse for your area as some have suggested. You did NOT tell us the BRAND or MODEL of your Radio Scanner.
