Stupid Simple HT1000 Question
RadioDitch
Field Operations Member
Not Where You Think
Just purchased a used HT1000 since I love the ones we currently use on our rescue squad. I'm probably at some point going to want to hook it up to a mobile antenna on occasion. Therein lies the question. Am I correct in recalling the radio uses a reverse SMA?
Thanks in advance guys! :)
kb5udf
Louisiana
Yep
You got it. The radio has an SMA-Male base, and uses antennas that are SMA-Female base.
FYI adapter cables are commonly available from the usual sources, ebay etc.
They also make tiny little "barrel" like adapters to go between reverse and regular SMA connections,
but as always I'd avoid any extra connections and just use the right connector from the start.
KC8QVO
Be careful - regular SMA-F connectors will not work. I just started a thread regarding this. The center pin of a normal SMA-F connector is sunk down inside the casing about 3/32-1/8". This makes the center pin in the radio's antenna jack not make contact with the center pin in your SMA connector (whether that is an adapter, barrel, or SMA-F directly on coax).
If you take off your antenna you'll note that the SMA-F connector on there has the center pin and dilectric flush with the casing (edge of the threaded part).
FFPM571
Nashvillle
I have the original motorola adapter that uses the speaker mic connector with a BNC style connector that you can attach to an external antenna.. If your intrested I have an extra im willing to part with.
KC8QVO
Does the adapter work with a speaker mic? Does it require a speaker mic or does it clip on in place of?
FFPM571
Nashvillle
It takes the place of a speaker mic. Its clips on and off the same way. It works 100X better than any adapter that screws on the antenna.
ramal121
Lots and lots of watts
Calif Whine Country
Arrrg! Kenwood has the SMA connector that is recessed and Motorola uses the flush center pin. I'm always losing stuff and it seems I always have the wrong SMA to BNC adapter to work on a HT1250 and it won't connect to the service monitor correctly. I take the recessed adapter and file the bottom threads off until I can get it to screw down enough to work on a Motorola. Usually works if there are enough excess threads on the adapter.
