STX 821 <<receiver problems>>
We have aquired an STX 821 (for type II) portable for a spare.
After programming, the radio had very poor receive quality, more like static than a recognizable transmission (off the system). Simplex transmissions were very clear (when transmitted by a nearby radio). Believing this to be a bad receiver in the radio, we took a known good radio (the type I equivalent) and did the board upgrade, hoping this would work. SAME problem. The radio transmits to the system fine, and will receive an occasional transmission (appearantly on particular frequencies in the system) fairly clear.
Has anyone else had this problem? If so what did you do? :( :( :( :( :(
Is there a way to check and see if the spacing may be incorrect in the stx software (if there is, I'm blind as a bat) ?
821 rx Problem
Here is something else wierd about it:
When trunking, the receive is only static,
But if we put the system channels in conventionally, the audio is crisp and clear!?!?!? :( :!: :?:
Seadoo
If the system frequencies you are trying to use the stx 821 on is in the 865* range, That will cause the radio to receive static if it is not of the gps or gpl version as they will only receive up to 860* mhz. find out what type of controller it has in it.
Seadoo
georgiafire133, Also pm me if you see me online as I have just moved into georgia and I have like 8 stx radios. I may be able to help you out.
