Subaudible LSD Format
UPMan
In Memoriam
Arlington, TX
Anyone have a reference they can point me to for the subaudible low-speed data on Motorola analog voice channels?
WayneH
Forums Veteran
Super Moderator
Your master site
FWIW, all the info contains is a TG id (with LSB stripped).
When a radio is programmed for Priority Monitor scanning the radio sees the talkgroup in the stream and reverts back to the CC. Real simple logic.
The PRO-96 will display the datastream when you park on an active voice channel.
-Wayne
DaveH
Ottawa, Ont.
If I recall, that was what confused the original PRO-92.
(non A or B) That's why I avoided it.
Dave
WayneH
Forums Veteran
Super Moderator
Your master site
Dave
Exactly. When you used the scanner on systems that assigned talkgroups sequentially (versus odd numbered) you ran into two groups that when seen over the LSD on the voice channel looked the same due to LSB loss.
(To those wondering what LSB is: LSB is least significant bit or the right-most bit in a binary set of numbers)
-Wayne
