Nope, should be good.So far I have programmed the P2 using the database from RR using Freescan.
Is there something more I need to do? My scanner experience was basically using crystals
Yes, the Toughkennamon tower is closest to my location in Pike Creek DE., New Castle County has a tower on rt. 41 just north of Hockessin, almost in line from my location with the tower in Tough.
There is also a cell tower not far from my location just to the west of me, probably within 3/4 mile.
Currently I am using a mobile antenna, indoors, magnetic mount on a heating duct in my basement. I can clearly pickup New Castle County and 3 weather broadcasts as well as Salem county NJ fire, Cecil County fire & Delaware railroad, Chester County fire dispatch on 160.1850 as well as aviation traffic.
I do expect to run an antenna lead to my garage to get an antenna above ground and hope to get a little more.
Thanks.
I would assume that your issue is antenna placement then. When i take my radio from the firehouse to my parents house in Concordville PA it always drops signal when im in the basement, even with the WCB cell so close. Maybe take the included antenna and the unit closer to a window and see what you can get?
I have tried that using the provided antenna, but did not get anything. I plan on going mobile with the scanner and taking a ride up to Toughkennamon/Avondale to get closer to the tower there and see what happens.
I would think any antenna above ground has to get better reception.
Thanks.
Wondering if an attempt is even worthwhile on the northwestern edge of Lancaster County.
Coincidentally I pull in the conventional channels like gangbusters.
