Suffield Fireground Chs
xplorer417
AGAWAM MASSACHUSETTS
hi all maybe someone can help out on this one that know the suffield area i do i am geten confused on the fireground chs now which one to listen to i know they are simplex why do they need three small twn they are
the old FG CH 14 151.xxxx says in the scanner master it is now a the input to 156.xxxx
fireground 1 150.7750 D134
fireground 2 155.36250 D134
fireground 3 159.1275 D134
TACTICAL 153.9500 ever in use
svs 173.2250 unkown what this ch is for would this be for a mobile repeater on the rigs
CT22
Banned
CT
173.2250 is licensed as a MO3 for Suffield EMS so its a vehicular repeater... not sure if its used.
PJH
The RR.com listing is correct. Don't know about scannermaster
PJH
Forgot to add..
The old primary channel of 154.13 is still licensed, but not sure how often..if at all.. its used. 99% of all calls are on the repeater 156.07500/158.94000. I believe the old fireground "Fire 2" of 153.95000 is still programmed into the radios.
xplorer417
suffield fire ch
this summer when they the had the fire in windsorlocks at the mill i was switching to see what was going on and heard units responding to the scene on the 151.4300 i thought to myself that was odd that was the fireground ch 14 then i switched to the main ch i have heard suff on that ch like when they had the fireworks for the july 4 celebration when command has wanted the units to go to simplex so they won't tie up the the rptr ch 156.075 for the detail.The scanner master says that 151.4300 is the input to rptr ch.hmm
xplorer417
hi all can someone re confirm theses if anyone is on here that is on SUFFIELD fire or can help out w identifying theses freqs here is the freqs again adding one to it
fireground 1 150.77500 D134?
fireground 2 155.36250 D134?
fireground 3 159.12750 D134?
TACTICAL 153.95000 141.3?
FIREGROUND 154.13000 141.3 life star?
