Suggestions for a new better quality SDR dongle
LISAS_AUDIO
Ive been using one Noolec for a P25 Type I system with great results only odd issue is all calls are grouped or patched rendering Tg ID useless...added 2nd dongle same...tho Unitrunk shows tg ids 100 % perfect...any ideas
thx
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
I have been using the same 2 RTL-SDR dongles for years now and I want to upgrade to a better quality one. I use it mainly for general scanning on an 800 mhz trunk system and I like to use the "scan" function in DSDPlus to listen to and find new DMR and NXDN freqs. I use both SDS Plus and SDR Trunk but I find the audio quality on SDR Trunk MUCH better. Anyway I am not sure what I want to get. I dont want to listen to HF, just the systems I have been listening to. I want something a little more robust I can take to work and run off a tablet or small laptop.
Hot take but there's nothing wrong with what you have for what you are doing. Sure an Airspy/Hydra will have more bandwidth and better dynamic range. But you might not see much improvement over how things are now.
Buy a newer RTL-SDR Blog/Nooelec dongle and deal with driver and software compatibility because of the built-in HF upconverter you won't use.
Buy an SDRplay if you like supporting an awful company that targets end users when their products go missing and who couldn't figure out how to make the hardware do full frequency coverage when they first came out.
If you really just want to blow some money, maybe get an Airspy mini and see what you think. I have an R2 and it's a great unit but may be more than you need for your application.
I last bought a USB-C version Blog v3 and it does a fine job.
EW1407
I replaced all my RTL-SDR v3 and V4's with 2x RSP1b and 1x RSP1a for my feeds.
So far no complaints.
StoliRaz
£uck Encryption
Just bought a nooelec v5 on amazon hooked up downloaded unitrunker no signal at all zero same antenna i've used on my bcd 436 an sds 200. I now think Amazon is the place to stay away from.
Or it could be that it works fine but you need to adjust your gain/other settings on the software you're using
KQ4ZVY
Is it possible the V5s need custom drivers just like the V4s did?
Whiskey3JMC
Just another pesky scannist
Simulcastylvania, TE
I bought a Nooelec V5 from Amazon last month, all I had to do was the usual Zadig driver install. Dongle works as intended
dmchalmers
Way not enough information. I have ordered at least 12 of these including 2 last week. Every one has been fine with SDR trunk and other applications. I see many buying this stuff who dont understand it and not knowing how to install and setup stuff and saying its bad.
I beg to differ Jeep. I've been in numerous e-mails with Nooelec an they can't tell me why their website will not let the Zadig downlod work nor will the dongle be recoqnized when plugged in using dsdplus. Last RTL-sdr i bought "Also" from Amazon came shipped like this v5 in a Ziploc bag in a paper shipping bag. Zero protection! Amazon just refers you to Nooelec an wants payment to replace.
