suggestions for mobile antenna on BCD996T?
kraziebill
central IL
I'm looking for some suggestions on a mobile antenna to use with the BCD996T. It would need to have a ride freq coverage (154 - 900MHz).
Your thoughts would be much helpful.
Thanks in advance.
wyldman
Center of the RF Universe
Find out how strong the signals are that you want to monitor first,as well as if there is much interference nearby.
I kept trying better (higher gain,or band specific) antennas to try and improve reception.If anything,it kept getting worse.It was overloading the receiver,and causing problems.Now I use a unity gain all band low band antenna,which does well on everything.
You will have to experiment first,as it may not be the same in your location.If you find your 800 signals are very strong,but need help pulling in the lower bands,then a 2M\440 antenna will probably work well.If it's the opposite,an 800 Mhz antenna may work well.
