(Suspected) MacDill AFB P25 4A8-BEE00
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Hi all,
I thought it would be wise to split this off from the discussion of the Hillsborough P25 system.
I found 4A8 the other day doing a CC search. Several members have suggested that the frequencies in use involve some freqs used on the MacDill Motorola system in the past.
Here is a link to the PRO96COM files for this system, as I have compiled them - dump logs included.
http://dl.dropbox.com/u/52433753/Radio/PRO96COM Shares/System4A8.zip
RyanRox099
Tampa, FL
Hi all,
What program did you use to get this info?
Jay911
That's from a program called PRO96COM which uses a scanner with the CC Dump feature - which outputs the data from the control channel in a text format through the USB/serial connection - and translates the data into "human readable" data.
If you search for PRO96COM on the forums here you'll find many topics. It's written by the same fellow who makes PSREdit, another good piece of software for GRE scanners.
