I dont see south bay law talk groups 9 to 16 in the data base will there be an up date for this ?
There will be if there is a submission.
Has there been a talk group update for santa clara PD ? My scanner has been silent for a while. I have heard transmissions on line so there is some activity.
Is anyone having issues monitoring Sunnyvale PD on the SVRCS system?
I have a set up in Cupertino area with a WBD-40 Discone Base Antenna connected to 6 Uniden BCD996P2's running RangeCast software.
Im picking up San Jose PD and numerous other municipalities but having severe audio issues in regards to Sunnyvale PD on the SVRCS system, whereas other channels on the system I'm monitoring are coming in 5x5.
Wanted to ask if there were any recommendations on improvement or if anyone else is experiencing the same?
What site are you monitoring?
Cupertino and 9 miles away sounds like you are listening to the Central Cell. Try programming the West Cell and see what your results are. The closest tower to Cupertino should be Doyle and Lawrence. No issues with a 436 at De Anza and Stevens Creek.
Not quite sure what this means, Or how to go about it? Looking at the database I don't see a specific "cell" listed. Mind PM'ing me the information or directing to a site with the info? Thanks.
Do the West and Central sites receiving the same traffic or is some traffic only on one site.
Ok, just got the Yagi, here's my experience so far (just have had it set up for 30 mins or so) -
I don't have a stand yet for the Yagi (I cannot mount it outside), so I kind of just have it propped up and leaned against a lamp on my end table.
After playing around aiming it in different directions I think I found an orientation where I seem to get decent reception of SVRCS. Big difference!
Since the antenna is pretty precarious once I have it on a reliable stand and perfectly stable and vertical and I can rotate it precisely I think I can get the signal even better. It's not perfect right now, still get some clicks and pops and distortion but it's finally readable audio and many of the calls are perfectly clear. I'll turn on the error rate at some point to see.
And some other good news - the other conventional systems I monitor (Med 91, San Jose, Mountain View, etc) don't seem to be impacted too much! It's an 800MHz cellular Yagi, but I still pick up the 460MHz systems ok.
The conventional systems all come in much louder than the P25 system. I will have to mess with the volume offsets I think to balance them out.
I have a 436HP so the coax comes out the top. It's really stiff, and I don't want to stress the connector. It doesn't really stand upright well due to the coax pulling on it, so I have it laying on its back. I can keep it this way but then I can't easily read the screen.
What do people do in this case when you have a handheld?
