Par EF
FWIW I shot an order today for a PAR EF-SWL. I want to see if it'll perform better than that bastard wire I have now
it seems like I will be happy with it as I have a good groundpoint up there ready and that 9:1 transformer just may be the ticket. I will let y'all know once I get it and install it
I ordered one of these along with an apex 302Wa-2. My impressions: The apex is of course a vertical.
where as the EF is a wire with a Balun. First of all when I recieved the EF I was immediatly disappointed.
It appears after Mr. Par sold the co. the new company started cheapening it up. The EF is/was advertised as
14 ga. flexweave, the new ones are not. They are 18 gauge wire similar to MTW wire.)machine tool wire)
it is supposed to consist of 137 strands of small diameter strands. The 18 ga. wire is 19 starnds of .010"
each. I put it up and grounded it well ( 8' grd. rod) to the balun. It was a sloping design 15' high down to
about 9'. Daytime reception was very noisy, the kind of hiss from the suns ionizing that you cant get away from. Night time was somewhat quieter but still not great. With that 18 ga. wire I doubt it will last thru a hard Iowa after the ice starts to build up on it. I do not like how they use the antenna terminal on the balun as a support for one end of the wire. I see this as a weak design. I put up the apex vertical and ran both coax's to a 2 position coax switch so I could switch back and forth on the same signal. After testing from 500khz to 30 mhz. The apex is a very finely made Japenese antenna with a built in impedance match
to make the antenna look like 50 ohms over the spectrum. After picking out weak signals all through out the band, my impressions are on some freqs. the EF had a stronger signal but with a corresponding higher noise floor. On the same freqs. the apex had a somewhat lower sig. but it was also quieter. In no case could I hear a station on one ant. and not hear it on the other. I will have to say I ended up preferring the apex, and will be taking the EF down. I would much rather listen to a lower but clearer
signal than one that is the same signal with more noise in it. I do have a 10 db preamp on my radio to make up the difference. Anybody that has space limits or apartment living I would heartily recomend
the apex any day. I'm retired now and have been a swl for at least 50 years and tried all kinds of antenna configurations, with varying success with each different antenna I have had up. 2 of them Im partial to.
Rf Systems MTA and now the Apex 303-2, both of them are verticals.
