markanderson
Let of traffic on Sw ma-1 at 8:30pm
. I seem to remember that use of SW MA is supposed to be coordinated through IDHS but I'm not entirely sure.
For the Paoli fire the SW group seemed to be used for coordinating units incoming from other areas, so another possibility is they wanted to be able to work with units coming from well out of the P area (and neighboring areas who should have P-MA's programmed in) such as Indianapolois. In this case, use of a SW group would be appropriate.
ScanNEIN, I only heard a bit of the Paoli traffic, did you get any insights into how the SW-MA group was being used?
None of the groups ever have to be coordinated, it's basically first come, first served.
I am like you, I thnk they were directing incoming units.
During rebanding, all radios in the state are being reprogrammed to include all regional MA's. So, no matter where you are, you will have access to that set of MA's.
Yes, correct, however not all radios currently have all the regional groups, the second problem is the regional groups only work in the region assigned. P will not work in Indy and H will not work in Paoli or affiliate unless the State operations center makes some changes... and it appears that none of the fire safe-t radios have dynamic regrouping ability either.
The training on safe-t radios was brief, and static = watch the power-point please, and not hands on in any way shape or form... (The trainer had his radio, but none were provided for the participants)
in fact the use was discouraged (at that time) by emphasis on how the State will "shut off" your radio for mis-use or incorrect use etc.The chief will be asked to give the radio to someone else becasue of mis-use.
Some radios stay off in Washington County, because of that training despite EMA's request that they be used to show the State we are using and "deserve" more money to buy more radios. Bottom line this is what you get when you need them, and this was a minor incident. And the guy that trained me is a state-wide trainer who is training other to give the same presentation.
After rebanding, whether it is first touch or second, the radios will have all Regional MA's in them.
Says who?
I understand the above, however ScanNEIN states:
There is nothing IPSC has put out to validate the above quote. That maybe what is happening in one part of the state, however it's not wise to give people false information.
There are some daily users of the system that have a hard time navigating through one zone, let alone if you add 4 more zones. Granted it's no excuse, however it's reality.
