just need to reprogram the brick with the selection above to let it know that its communicating with a CH100 now and not a CH721
For clarity: That will create a personality (mission plan) for ch100 that you preferably load via the USB port on the ch100 head, not via serial to the brick. You don’t really wanna put ch100 plans into the brick. Yes, you can write a single personality to the brick when using a ch100, but you can’t read it back via USB or Bluetooth on the head.
The bricks that run ch100s that I’ve seen have no personality stored in the brick at all, which is why I suggested clearing the flash memory with the VA menu, which removes any personality stored in the brick. As long as the firmware matches between the head and the brick, the brick should operate with no local personality (the ch100 head remote fills the brick each time you power up the radio).
@mancow guess it wouldn’t hurt to write a ch100 personality to the brick, but just remember that wont be the preferred way to program the radio in the long term if you want to use usb or Bluetooth to add up to 10 mission plans to the head so you can switch between them.
@KC8ONR are you saying that you need to do this a single time when changing head types? I’ve never experienced this before, so I figured the issue was trying to go from remote to front mount, not just changing the type of head in use. When swapping from remote 721 to remote ch100, I’ve never had issues with the unit being recognized.
Pretty sure I’m gonna list a ch100 remote head pretty soon. Haven’t been using mine much and the HHC731 goes great with my Codan radios that also use HHCs.
-B
