intisur
Is there a trick to switch or change between SERIAL MODE and MASS STORAGE MODE without shutting off the BCD536HP and then turn on again?
I mean using software commands or next updating firmware?
Is there a mode to select when you record only one or some TGID, or system, or department. I see that I can rec all or nothing.
And then is possible that BCD536 merge one record file in each TGID, SYSTEM or Department with each TGID instead of 200 little wav files that I have to join with audio editor before listening properly together?
Thanks in advance.
Intisur
Thanks in advance.
Intisur
