Anytone Sync Multi D878UV Codeplugs
gskroll
Portland, ME
I own 3 AnyTone radios (kept a different locations)
Anytone AT-D878UV
Anytone AT-D878UV Plus
Anytone AT-D878UVII Plus
i think I understand (correctly?) that I must use one “edition” of V3.03 CPS for the first two (v1) radios and must use a different “edition” of V3.03 CPS for the newest (v2) radio.
My plan is to use the same codeplug that I had maintained for the UV and UV Plus radios to open in the newer “edition” of CPS to send that codeplug to the UVII Plus. Should this work?
Is there a better approach to successfully load the same codeplug “content” to the three radios?
My attempts to do so have resulted in moving channels, zones, scan lists, etc but not moving settings from the “optional setting” category in the left tree in the CPS (for example, Power-on, Alert Tone, or Key function).
Any suggestions?
Glenn
