Sys ID in Search vs Sys ID in Analyse
enosjones
Price, Utah
My cap+ system isn't showing system ID it does show site id however and that's accurate ...
Checking nxdn 9600
2 systems
UBET system is sys ID 66 on search
On analyze it says sys ID 00042h
Peak wireless is system ID 64 on search
On analyze it's 00040h
Site IDs on both are correct just not the system IDs...
Sent from my iPod touch using Tapatalk
jonwienke
More Info Coming Soon!
VA
The numeric value is the same and correct in all cases. The only thing different is the display formatting. 64 decimal is 40 hexadecimal.
radioprescott
East Central Arizona
And here's another example...
A new T3 system in Yavapai County, AZ
Search = Net1, site 23, cc10, DT3
Analyse = 001h, Site 23, cc10, DT3
DSD+ = Network H2, site H2-3.8, cc10, TIII
enosjones
Price, Utah
Yes tier 3 is different on dsd plus than Uniden does. Questar Dominion is 1.3 1.8
I have not analyzed tier III yet , let me try...
So far ... Only site info. No sys ID on one site,
Only site ID on the 2nd site too no other info, and no activity at the moment, Friday evening
So T3 isn't showing info on the system at the moment just site#
Voyager
I just heard back from Uniden. System Status is fixed hex, and Custom Search is fixed decimal. (fixed meaning set to that in firmware and cannot be changed)
I thanked them and suggested that perhaps it could be changed to be a user option that follows the setting, as it is confusing to have multiple formats.
I believe the rest is up to UPMan.
In the mean time, or if this is not changed, just understand that one is decimal and the other is hex (hex has the h at the end). Your PC has a calculator which will switch between the two.
enosjones
Price, Utah
When u get that system figured out I'd submit it to the database
enosjones
Price, Utah
Thanks for trying, if you've also sent the info or the link to this thread to Upman then we will just wait and see what happens
Voyager
You're welcome and I did. There is a lot on their plate right now, but then again look at all the x36 updates. I would not have existed those with the work on the SDS.
enosjones
Price, Utah
1.18.00 is out but no update to this issue, so I mentioned it in the 1.18.00 thread so he could at least see it, right after he started the v18 thread..
Voyager
As I stated previously, this is working as designed. I would not expect a user option to be added so quickly (if ever).
