SDS100/SDS200: System Hold
cpohlad
Midlothian, VA
When I am traveling and running on Full Database mode with my GPS puck, I typically like to tap the System button, scroll to the county or system I am looking for and then try to get it to stay on that. This is a bit of a frustrating process to make work, so I was wondering if there is an easy way to do this so I can manually select a top level system?
TexTAC
Press “System” once and wait for it to lock on the current system (you won’t be able to scroll off that system once it locks on). Now press “system” again and scroll to the system you want and when you stop scrolling it should lock on to the system you stop on.
n1chu
Farmington, Connecticut
I found hitting the Channel button first (instead of the System button) will cause a hold and then, after the hold button takes, hitting the System button, waiting for that to take, and releasing the Channel button works.
