System Key
James04TJ
Can someone clarify a point for me? Is a radio system hex ID the same as the system key?
n5ims
Assuming you're talking about the Motorola trunking system, no. The hex ID is a 4 hex digit code used to identify the system. This is easily decoded from the system's transmission.
The system key is a file used by the RSS or CPS software to allow the radio to be programmed to access that system. This file is a fairly small encrypted file that is only (legally at any rate) given by Motorola to the owner of a trunking system. Any requests for the file by unauthorized folks will be politely refused by Motorola.
James04TJ
I figured as much... I am just notused to hearing the term "hex id".
ILMRadioMan
The road to no where.
That could also stand for a talkgroup hex.
As you may not (or may) know, when talkgroups are programmed into Motorola radios, they are programmed using the hexidecimal version, of its decimal ID.
