System Site Question
918Dave
Glendale, Arizona
Was wondering if there is a way to manually select a Systems Site for the G5?
I've been able to use a different site by turning the radio off and back on, but thought I'd ask if there is a way to accomplish this thru the menu?
APX8000
Sarcastic Member
AES-256 secured
Yes, you have to program each site as it's own system basically. So only program the control and alternate channels and the site ID for the one that you want to hear. Then you create a zone and select that system only and apply the talkgroups to the channel knob position.
I'll use NC Viper as an example. When I'm driving up and down I-95, I have all the sites programmed in along with the talkgroups for NCSHP that cover I-95. But when I want to monitor a particular county that I'm in, I create a separate system that has only those sites and talkgroups and assign that to another knob position.
BenScan
D/FW
It's not obvious, put you can copy and paste(by right-clicking) whole systems in the programming software. Sometimes it's easier to do that, and change the site settings, rather than building each one from scratch.
