BCD996P2: Systems Auto-Copying in scanner
ME343
ME/NH/VT DB Admin
Farmingdale, ME
It seems my scanner is auto-copying all the systems I have programmed. I program it by PC and than go back to fix something in the system is in there twice even after the PC program overwrote the system with the same name. Very annoying when running a feed and having to fix issues daily.
ME343
ME/NH/VT DB Admin
Farmingdale, ME
I usually have it set to overwrite. But just today I had to fix an issue and did it from the scanner directly. and noticed the systems were copied and deleted them from the scanner and than i went back an hour later to adjust a setting via the scanner directly and the duplicates were back
CT
Download the file from the scanner - delete the duplicates - SAVE - Upload to scanner and REPLACE any existing system (duplicates.)
pb_lonny
Tasmania
Data only gets in the scanner if you program it that way, check your settings in your software.
