Systems Saber III Error
DPH11
Sayre, PA
I am trying to program a Systems Saber III and keep getting "Serial Bus Communications Error! Could not acquire busy line. Turn radio Off then On to try again." I do, and the same message occurs. I am using the same computer, RIB, etc that I use for HT600s, MT1000s, HT1000/Visar, etc. so the computer shouldn't be the issue...
Any ideas or suggestions???
Astro25
Chicagoland
Try checking the COM port in the computer configuration settings. For some reason most RSS will always default to COM2 whereas you want COM1 in most cases.
rescue161
KE4FHH
Hubert, NC
Just to make sure, you are using Systems Saber RSS right? Just asking, 'cause I've seen people try to use Saber RSS and it won't work.
DPH11
Sayre, PA
Yes to both... I actually tried using both com ports, just to see if that was troubleshootable. No dice. And I am using the ver 3 of the Systems Saber software. The radio is CON5.0.
Thanks for the ideas though!
FFPM571
The Mid South
check the battery in the RIB if its weak you can get that too.. Or make sure you have a saber cable not an astro
DPH11
Sayre, PA
The RIB that I have plugs into an AC outlet, and the cable is supposedly for a Saber & Systems Saber. The pin configuration corresponds to what is listed on batlabs for the programming functions. Like I said, its the same RIB, PC, everything that works for other older Mot radios...
FFPM571
The Mid South
did you try cleaning the contacts with a pencil eraser and make sure you have a good contact when the cable is attached
