ka3jjz said:T4Win is probably not the best choice since it hasn't been developed in a while - UniTrunker is a better bet.
Did you put a discriminator tap in the 2051? Because of the reshaping done in the audio amp stages, you cannot just feed speaker or headphone audio to trunking utilities like UniTrunker. A discriminator tap is required. 73s Mike
rfmobile said:You will definitely need a discriminator tapped radio. Unitrunker can support a data slicer but it is (a) very experimental and (b) only works on 2K and XP. I can't remember if T4Win was given that capability or not. Most folks use a direct sound input.
Someone just needs to shine flashlight on the main circuitboard and locate the FM IF chip.steve2004 said:too bad the Pro-2051 is still unknown (it is keept in such secret by R-S )
Likely so. Are you able to get 100% decode on any area signals?steve2004 said:Does it look like I found the Discriminator tap of the Pro-2051 ?
rfmobile said:Likely so. Are you able to get 100% decode on any area signals?
Also, with the tap in use - does the speaker audio drop out or loose volume? Does the squelch still work. Sometimes adding a tap will affect these.
-rick
