T4WIN - Q. re: finding a system's frequencies
HowD
Ozaukee County, WI
Here are some screen captures of a system. As you can see from the ACTIVITY window, there are frequencies listed. Is there some reason why the frequencies are not displayed along with the LCN in the list that is saved to .xml?
I'm using a Pro-2006 only, no computer control.
Select the system in the left-hand "Database" panel. From the top menu, "Tools" -> "Motorola 800 Band Plan". Your frequencies are set.
If you are only missing one or two channels you can also use the "Tools" -> "Extrapolate" function to fill them in.
Beware that under poor signal conditions, you may have a few erroneous channels listed.
-rick
ka2mek
Hi HowD
I am watching the SAME system you are here in MONMOUTH COUNTY and if you improve your reception then T4W will work just fine.Here near Sandy Hook I get 100% signal and this program is tracking it without any trouble what-so-ever.Thank You Rick for a WINDOWS based trunktracking tool and I know as time allows this will evolve into something fantastic(I already feel it is a fantastic piece of software!)and it is so simple to set up and use!No more fooling around with DOS hooray for Rick!Thanks Man!
73!
Dr.Robert Salvo
KA2MEK
Middletown NJ
