T4Win will not work need help
When I go to open T4Win after unzipping it I get a message saying it has generated an error and will close.
I am useing windoes 2000 and I have a BC780XLT
Just wondering if anyone knows why I am getting an error
Please read the FAQ document included with the zip file. Post any additional questions here.
-rick
My computer meets the requirements to run this program but it still generates an error. I tried downloading it twice and I get the same thing.
Probable cause #1
Have you run an earlier version of T4Win prior to this? If so, the preferences file format has changed. Look for the following file named "_t4winprefs.xml" (note the leading underscore) in the current user's application data folder.
Example:
"C:\Documents and Settings\userid\Application Data\_t4winpefs.xml"
Probable cause #2
Do you have MSXML 3 or MSXML 4 installed on your system?
If not, the download links are in the FAQ document.
Regards,
Rick
I do have MSXML 3 installed on my computer and I could not find
C:\Documents and Settings\userid\Application Data\_t4winpefs.xml.
I even ran a search on my computer.
Also I did use an earlier version. The program would run but it would not decode the control channel. I am wondering if the trunking system I am trying to use these will work with T4WIN. I am trying to use with the Lowndes County, GA trunking system. It is P25 3600 baud digital system. I am use a BC780XLT with a discrimanator tap into an audigy sound card.
Just to give you a little background on what I have tried to use in the past.
ka2mek
Are there any versions of trunker that work with just a sound card input?or are they all serial data port driven and needing the "box"between the scanner disc-tap and the com port?thanks
Rob
Trunker only accepts input from a data slicer attached to a serial port.
-rick
