Tabletop Shack Setup
mikewpu04
Ocean County, NJ
Glad to have had the time recently to reprogram these scanners and add a 996P2 to the lineup. I can just about monitor everything available in my area. I was pretty stoked to get ProScan working with these using a Mac Mini running VMWare/Windows 10.
mikewpu04
Ocean County, NJ
Well, a bit of an upgrade. Added the rackmount and a BCT15X for fast scanning of all of the active analog frequencies in the area. The BCD996XT can listen to the Phase 1 systems in the area and the BCD996P2 can listen to the P2 systems.
What should go in the top slot??
mikewpu04
Ocean County, NJ
My tabletop setup is officially complete. After months of indecision, I decided to spend the remainder of my stimulus check on an SDS200 with a DMR upgrade. I have officially used my entire stimulus check at ScannerMaster.
I wasn't having any decode issues with the BCD996P2, but I figured it would be best to learn the SDS200. With this setup, I shouldn't have to buy another radio for a long time.
Here's my configuration:
SDS200: Monitors NJICS, USAF-Joint Base McGuire, First Energy, NJNG, New Jersey Turnpike, and various township trunking systems (DMR and P2). Going to setup a custom system with DMR single-active freqs that ignores analog freqs.
BCT15X: Monitors all active analog channels. I weeded out all of the non-active RRDB listed channels in my area and this scanner zips through the available 60ish analog channels in a few seconds.
BCD996XT: Monitors the NJ State Police full time.
BCD996P2: Monitors the Ocean County 500 and 700Mhz systems full time. Can also back up the NJICS if needed.
