TAC A on the state wide network is being used for the Berlin fire just put that out there talk group 1503
I don’t see TG 1503 listed under transit. It’s an interoperability channel, supposedly available to all in the public safety groups and assigned as needed. Maybe there are busses assigned to the fire for transporting firefighters to and from the fire and their staging area? If they still follow the rules when I was a district fire warden they are required to rotate their crews in and out for food (which was every four hours) and rehab.Why Ct transit come up on the system
I’m guessing he hasn’t excluded those transit TG’s. And why would he list Troop B? That’s in Canaan. I added TG 1503 this morning to the DEEP TG’s, labeled it as INTEROP TAC A BERLIN FIRE and chose Interoperability as the type. When the fire is extinguished I’m just going to Avoid that TG until the next time and change the label.You are probably right maybe Connecticut transit has that channel but you do see in his list Connecticut transit popping up
I entered a few TG’s in anticipation of Avon coming on board. I used 10401, 10402, 10403, 10411 and 10412. I believe I got the right town tax code number and followed what Newington is using for their fire dispatch (19411). So far I’ve not heard anything for Avon. I sent out a few requests to the Deputy Chief in Avon (who is heading up the effort-he’s also a ham) but got zero replies. My guess is they aren’t close enough to assign the TG’s, so he has nothing to reply.I did wonder about that one.
I noticed that I've only logged a handful of radios with a 44xxx ID rather than the typical 45xxx CT Transit uses, so it's entirely possible that this range of ID's is for something else (Town of Avon?) and my tagging is wrong for that particular one.
If Ct. Transit is using that TG, it was probably done by over-the-air programming. I believe CLMRN has that ability to do that remotely. When they don’t need it anymore they will remove it… but I’m just guessing.You are probably right maybe Connecticut transit has that channel but you do see in his list Connecticut transit popping up
Troop B Is the site (012 (C)) that I am tuned into.I’m guessing he hasn’t excluded those transit TG’s. And why would he list Troop B? That’s in Canaan. I added TG 1503 this morning to the DEEP TG’s, labeled it as INTEROP TAC A BERLIN FIRE and chose Interoperability as the type. When the fire is extinguished I’m just going to Avoid that TG until the next time and change the label.
All subscribers on the network (are supposed to) have the interop template which includes tac AIf Ct. Transit is using that TG, it was probably done by over-the-air programming. I believe CLMRN has that ability to do that remotely. When they don’t need it anymore they will remove it… but I’m just guessing.
