desertscan
- Joined
- Jan 15, 2012
- Messages
- 43
how are some feed providers getting away with feeding sheriffs tac channels?
negative. local incident dispatch advised all units working this incident to move to tac 2 this feed provider has all tacs programmed not the first time he feeds tac channels to his feedin my county, when something big happens that i think should be on a tac channel...
they leave it on the dispatch channel and have other units move to a secondary dispatch channel.
so the "phone" people are treated to all the happenings.
it also leads to a constant "unit XXX back from lunch" in the middle of it and then is told to move to dispatch X
which leads to tying up the channel with unnecessary talking than ever.
and there is no "channel in use" tone !
so could that be what has happened ?
how, where ? looked for email phone number or anything to report only thing is report problem. that goes to feed provider. where on broadcastify is the report button, email or phone numberDid you alert Broadcastify with the feed, date and time of the occurance?
YesAre fire department tac channels ok?
Submit a support request with details to support@broadcastify.com or submit a note to the feed provider.how are some feed providers getting away with feeding sheriffs tac channels?
TAC CHANNELS WILL BE DELETED....YOU MUST RUN THE SHI*TY FEED IN THE COUNTY.negative. local incident dispatch advised all units working this incident to move to tac 2 this feed provider has all tacs programmed not the first time he feeds tac channels to his feed
You must run the feed that was violating the TOS.TAC CHANNELS WILL BE DELETED....YOU MUST RUN THE SHI*TY FEED IN THE COUNTY.
