Tait TP9400 Programming Problem
ernestowalls1
I have a Tait TP9400 and Application 2.18.0.532. When reading the radio the screen on the TP9400 shows Please Wait for about 2 seconds and then the radio reboots. The Application then shows unable to communicate with device.
I have tried enabling Safe Mode under the Application options and have tried setting the baud rate limit but it doesn't make a difference.
Is there any special settings that I need to enable/change or any mode that I need to put the TP9400 in?
2154
I've been using version 2.17 without any issues but haven't upgraded to the 2.18. What cable setup are you using? Usually you should be able to just plug it in, turn the radio on, select your com port, then go from there.
ernestowalls1
I am using a cable from RFGuys online. I am thinking the radio might have been programmed with a security key. Would that give a distinctive error message instead of just saying unable to communicate with the device?
2154
Gotcha. Hmm even if so it would allow it to be read and then prompt for the key when you go to open the codeplug or edit anything.
